BUG REPORT: impossible to enable preview functionality when interface is set to Italian
It is impossible to enable preview functionalities when fusion 360 interface is set in Italian. I solved the issue changing language to english. Probably other languages are also affected by this bug.
RajkumarIlanchelian
@Anonymous Are you not able to select the preview in the preferences UI?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
I have to be more precise here because i think this bug is very well hidden. I'll do my best
1) When i initally had the interface in Italian it was not possible to enable preview functionality. ( i could click on them but the setting was not really applied)
2) After that i switched interface to english and as soon as i tried it worked. I think when i clicked a window showed up (i don't remember the content but i have seen it just one time). I think i was also asked to do a login. This is where the bug may be hidden, this specific part was not working with interface in Italian.
3) I just tried again to switch off and then back on with the interface in Italian.  Now I can disable/enable those functions without any problem.
I think this additional information narrow down the problem: To reproduce this bug i think you need to create a new account with fresh installation, then start fusion360 with interface in Italian and try to select preview functions. It should not work until you switch to ENG.
Please let me know if this helped
