Bug Report: Cannot Delete (Projected) Line
therealsamchaney
Message 1 of 9
therealsamchaney
I have a sketch with some projected geometry. One of the projected lines cannot be deleted. I can right click it and click delete and nothing happens. I can click it and hit the delete button and nothing happens. Somehow, Fusion has created an immortal line! Strangely, if I select everything in the sketch I can delete it all including the line. I should add that originally, this line was a construction line. It only became solid after I exited the sketch and then tried to extrude something in the sketch. So for some reason after that, Fusion either made this line solid or made a new line on top of it and made it impossible to delete specifically.
I can't attach the screencast because the Autodesk forum's own built-in "PASTE A SCREENCAST URL" and "MY SCREENCASTS" tools are still broken as they have been for years and cause the page to give itself an HTML error. So, here is a link to the URL of the screencast.
I can't post the file here because it contains valuable UP but if an Autodesk employee responds I can send it to them in a private message.
Replies (8)
Message 2 of 9
dsouzasujay
Hi @therealsamchaney,
Can you try, Right click on projected sketch, Break Link, and then delete the sketch?
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 3 of 9
therealsamchaney
I can right click it and click break link, but it has no effect. I still cannot delete the line. The only way I have found to get rid of it is to select everything and delete it all, but I need the rest of that projected geometry.
When I hold left click, I can see that there are actually two lines on top of each-other so I think Fusion created the immortal line. I can make it into a construction line which fixes most of the problem it's causing me but it definitely seems to be a bug.
Message 4 of 9
dsouzasujay
Can you attach the design that you have already completed in Fusion 360?
Can you File>Export your *.f3d file to your local drive and then attach it here to a Reply?
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 5 of 9
therealsamchaney
I can't attach the design because it has IP in it but I will send it to you in a direct message.
Message 6 of 9
dsouzasujay
Thanks for reporting this issue! I agree with you that this is a bug, reported as FUS-98655 in internal issue tracking system. Hope we get it resolve sooner.
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 7 of 9
therealsamchaney
Thank you! It's great to have some action being taken on these bugs.
Message 8 of 9
dennis.terenzio
Community Visitor
Community Visitor
As of Sept. 21, 2022 it still appears we cannot delete a projected line.
Message 9 of 9
jhackney1972
I have no issues deleting a project line.  Take a look at the video.  If you are having this issue, create a video showing your process and post it.  Add the problem file as well.
John Hackney, Retired
