[BUG] Pin slot joint turns yellow when it should not.
TrippyLighting
Consultant Consultant
TrippyLighting
When creating this pin slot joint it seems fine, but as soon as I accept with OK it creates a warning message.
The joint does seem to function properly, however.
I discovered tis behavior helping another user in their design in this thread.
That user states that atet 18 months he still hates joints in Fusion 360. One wonders why!
davebYYPCU
I too was working in the other thread, took some common sense to ignore it after a while, as both Joints working, have yellow icons.  I did not rebuild the assembly from scratch, in my work.
jeff_strater
@TrippyLighting , thanks.  I'll take a look at this and see what we can find.  Thanks for reporting it, and narrowing down the case for us.
Jeff Strater
Engineering Director
TrippyLighting
Thanks!
jeff_strater
Created FUS-47602 for this.  It is strange that it fails out of the gate like that.  I wonder if the error is misleading as to the cause of the problem.
I did notice that if I Revert the component positions in this design, and use As-Built joint, I can create the same joint OK.  Still not 100% sure that the motion is correct, but we don't get the warning.
Jeff Strater
rishabh.bisht
Hi @TrippyLighting, thanks for sharing this!
We reworked the internals of Joints and deployed a fix for this in the September update. Please feel free to report back if you can still reproduce it.
Rishabh Bisht
Product Owner
