Bug: Pattern copied components disappear during combine command
mamassey
Message 1 of 8
mamassey
Problem:
When choosing pattern copied components to use as tools with the cut command, all other copies disappear from view,  however they are still selectable.
Expected:
All components remain visible when selecting tool components for the cutting operation.
See attached screen cast.
Fusion 360 Ver 2.0.5688
Replies (7)
Message 2 of 8
jeff_strater
@mamassey - thanks for reporting that.  I can duplicate that behavior, and we will investigate it.  That certainly looks like a bug.  I suspect it is a recent change, since I think that behavior would have been noticed before.
[edit] the Fusion bug is FUS-50128
Jeff Strater
Engineering Director
Message 3 of 8
jeff_strater
follow-up:  Just got word that this bug has been fixed.  Not sure exactly what update it will be fixed in, but should be relatively soon.
Jeff Strater
Message 4 of 8
mamassey
Thanks Jeff.
That's great news
Message 5 of 8
@jeff_strater Hi Jeff. Still experiencing this in version 2.0.10356, macOS 10.16.0. I'm trying to join but all except the 1st selected patterned component disappears.
Message 6 of 8
g-andresen
Please share the file and name the parts or features involved.
File > export > save as f3d on local drive  > attach it to the next post.
günther
Message 7 of 8
jeff_strater
I apologize for my reply last March.  I was obviously mistaken, as this bug is still marked as open, and is still in our backlog to fix at some point.
Jeff Strater
Message 8 of 8
GRSnyder
See this thread also, which is probably reporting the same bug. However, that example does demonstrate that the issue doesn't appear to have anything to do with patterns or joints. It appears to apply whenever components are instantiated.
