Bug - Opening STEP Files Locks Program.
RDTymko
RDTymko
This bug is plaguing my everyday use of fusion 360.
This is happening while opening imported STEP files.  It is happening while opening several different imported STEP files.
See Video...
jeff_strater
can you share the original STEP file that this design was created from?  Thanks.
Jeff Strater
Engineering Director
RDTymko
I attached it to this reply...
jeff_strater
thanks.  Good news and bad news.  This STEP file opens quite quickly for me.  So, there is nothing generically wrong with either this file or Fusion.  However, that does not help you.  Can you try check your graphics drivers, and see what the graphics diagnostics help function tells you?
It could be something else, but often times graphics is the root of these kinds of issues.
Jeff Strater
RDTymko
Hi, I have tried a few different graphic configurations and the Issue is still happening.
This just started within the last update. So something has changed.
Richard
