BUG: Microsoft WebView2 required to sign in. WebView2 Runtime is already installed. Update* More serious issues.
NathanNation
Message 1 of 37
NathanNation
Frequent and fluent F360 user, never had any serious issues over the last year.  Opening F360 today and was greeted with a fresh login which doesn't happen often, usually I'm just right back in. Upon hitting "Sign In" I get a warning :
"To sign into Fusion 360, you need the Microsoft WebView2 component which is missing from your computer. You can download it directly from Microsoft using the Evergreen Standalone Installer method appropriate for your device."
I acquired the Evergreen Standalone Installer for the latest MS WebView2 component. Upon running it, the software reports WebView2 is already installed on this machine. The fact that I've signed in before- I can't help but wonder if this may have been caused by an update somewhere? Tried all the basics. Any help greatly appreciated.
Replies (36)
Message 21 of 37
ethan_ungerb
Observer
Observer
I love you so much mwah works very good 👍👍
Message 22 of 37
Cusd80_Admin
Same issue here, but I think my machine is experiencing some special issue.
When I first this Windows 10 machine, I uninstalled Microsoft Edge because it keeps searching things on Bing when I make a typo in Windows launch panel.
In the process, I denied admin group and system's access to the Microsoft Edge installation folder (which I think includes Edge Webview).
Evergreen installer says I have Webview installed already.
Tried resetting Edge from Microsoft store, didn't work because I denied machine's access to the Edge installation folder.
Idk, it kinda is my fault, but I never had any issues before Fusion updated their sign-in method. Works on my other machines.
Message 23 of 37
Bryancierniak
Same thing, very agravating.
Message 24 of 37
jon.z
Community Visitor
Community Visitor
This worked !
Message 25 of 37
Nyxius
I suspect edge is def at fault here. When MS wouldn't let me remove edge I forcefully removed it with malice using the regeditor and the Force delete options. MS still thinks edge is installed but I use brave as my default webclient.
Message 26 of 37
Nyxius
Yup, it was edge.  I reinstalled it and now its functioning normally.  I can't even begin to express how much I hate edge and how much this pisses me off.  I got rid of edge for a reason.  😠
Microsoft doesn't seem to understand to concept of consent and right to privacy.  So I got rid of them in every way possible.  It might be a shame if I have to extend this policy to Autodesk since I've been using Autodesk products for almost 20 years.  I stopped buying licenses when you moved to the subscription model and was starting to reconsider, but if your going to hold my work hostage and give me zero choices about what software I put on my computer, then I'm starting to think that the juice is not worth the squeeze.  I'm aware of other options and I'll be exploring those carefully.  Like if you agree and please feel free to pass my comments on to management if you think they'll  actually care.
Message 27 of 37
Bryancierniak
Any idea if you can add the web component to brave instead of fixing microsoft edge spy?
Message 28 of 37
Bryancierniak
FreeCad is getting better. Im starting to move over to there. Community is great. Software hasn't been that easy to learn, but changes are going quick!
Message 29 of 37
Nyxius
There's supposed to be a standalone install component, but its not working for me. Likely because I've neutered all the MS bloatware that I can. I know its an alien concept to MS, but I do like to use my computer for more than word processing. lol Background processes matter to me.
Message 30 of 37
Bryancierniak
I basically did the same, but since fusion refused to work at all, i reinstalled ms again. hopefully i can get out of fusion before i have more unessary problems...
by the way what is the standalone component? id like to get rid of edge...
Message 31 of 37
stevenromp
Community Visitor
Community Visitor
To those of you forced to add Microsoft WebView client to access your software. This workaround will work until  Autodesk decides to force you to have it constantly active, but you can install the microsoft's webviewer, use it to login  and then uninstall after using it until you have to login again. I don't know how long between checks it will work, but, I just wanted to pass what I found out to others.
Message 32 of 37
feamorx86
Community Visitor
Community Visitor
Just "Run as Admin" webview2 installer.
Message 33 of 37
LeAnhDuc
Message 34 of 37
manuelloape
Community Visitor
Community Visitor
I have the same problem, when I try to install Microsoft WebView 2, the computer tells me that it is already installed but it does not appear in the control panel or anywhere. I have tried uninstalling it in C:\ProgramFiles(x86)\Microsoft\EdgeWebView\Application\134.0.312483\Installer and it does not let me because there is a file that Microsoft is using d3dcompiler_47.dll
Message 35 of 37
LeAnhDuc
https://www.youtube.com/watch?v=bZevC7Ypp84
I find on web ,this video help you fix error
You must delete link in regedit across video youtube ,reinstaller software
Message 36 of 37
videogramme
Thanks for the advise, just run the installer as admin, quicker and easier than reinstall.
Autodesk need to put it in the"Troubleshooting Sign-In Problems" page here:
https://www.autodesk.com/support/technical/article/caas/tsarticles/ts/4ngKX13DPuGGYfKp7rnGzx.html#ab...
Message 37 of 37
armandovminecraft
Community Visitor
Community Visitor
This should be pinned
