Bug: Microgramma OTF font doesn't render on OSX
jarkman
jarkman
Most of my fonts work fine, but this one doesn't render as itself.
Font is attached.
Here's what I get, and what it ought to look like. Maybe Fusion doesn't understand the Extended variant ?
Screen Shot 2018-07-07 at 10.11.26.pngScreen Shot 2018-07-07 at 10.11.49.png
pawel.potyrala
Hello @jarkman,
thanks for posting! Could you share the font file (and possibly the design along with it), so that I can have a closer look and investigate if this might be a limitation?
You might also check out the following forum thread with some great ideas from @PhilProcarioJr about how to get text/SVG files into Fusion 360 to work.
Please accept as solution if my post resolves your issue, or reply with additional details if the problem persists.
Best regards,
Paweł Potyrała
Technical Support Manager
Global Product Support
My Screencasts | Fusion 360 Webinars
jarkman
Paweł - sure - here's the font and a tiny demo project.
Thanks!
Richard
ronstacooper
Community Visitor
Community Visitor
Hi there, I'm trying to install MicrogrammaDBolExt font into Fusion 360 but it wont show up in the drop down menu. I've installed the font successfully onto my laptop (it works well in a word document) and restarted but it still wont show up in my fusion font library. I've seen a couple of old forums on the topic but no resolution advice. Could you please let me know if this is possible or not? Thank you, Ron Cooper
ronstacooper
Community Visitor
Community Visitor
Oh and I've done the same with Eurostile font and it shows up in Fusion 360 so not sure what I'm doing wrong..
g-andresen
Then there are problems in the structure of this font, which are insignificant in 2 D applications, but cause problems in extrusions (e.g. self-intersection).
günther
ronstacooper
Community Visitor
Community Visitor
Thanks for the explanation Günther
Can you tell me if UGS can be added to the list of post processors?
Cheers
Ron
