Bug in move palette - labels not showing
othmane
Observer Observer
Message 1 of 11
othmane
Observer
Observer
At random occasions when I try to move anything (sketch element, body, ...) the move palette appears with no labels. Only the input boxes but with no indication of which is which. Also the copy toggle box is missing.
Any palette appearing next to the move palette also becomes blank (the sketch palette in the case of the example attached).
I am not able to determine the exact conditions when this happens. But when it happens for one elements, it keeps happening for this elements, no matter what. I can restart fusion, restart the computer, still the same. Then I try to move another element and it works perfectly.
Replies (10)
Message 2 of 11
Steven_Gao
It's a little weird behavior. Is it happened for a specific design or not? If yes, can you help to share the design file to us for further investigation?
Steven Gao
Fusion & Inventor Quality Assurance
https://www.autodesk.com/campaigns/fusion-360/insider-program
Message 3 of 11
othmane
Observer
Observer
No it can happen on any design, at random occasions.
Here is one of the design where it happens. When I try to edit the sketch6, and try to move any of the lines, I have the same phenomenon.
https://a360.co/3VU2bIq
Message 4 of 11
TimelesslyTiredYouth
Hi @othmane
Please upload the file so we can see if the bug is reproducable normally with other people and if it's just you.
File > export > save as f3d on local drive  > attach to post
Cordialement
Ricky
Message 5 of 11
g-andresen
There is no download permission for the file.
If you are using a personal license, upload it using the method described by @TimelesslyTiredYouth
günther
Message 6 of 11
Since when can the web viewers for designs become download methods?
*I take that back I found out that you can give download permisions via those web links
Message 7 of 11
othmane
Observer
Observer
Sorry for the lare reply. Here it is.
Message 8 of 11
Hi @othmane ,
Thank you for the file,
I and others will review it on your behalf; however, can you answer a few additional questions, please?
  • Laptop model
  • Do you get the Fusion slow performance warning?
    • If so, do you have your better performance setting turned to the correct mode?
      • e.g., shadow off, etc.
Kind regards
Ricky
Message 9 of 11
Right my voice is gone for no reason, but what I was trying to say is that the sketch and move function both load for me on my design, so it's confirmed that it's not a design issue but something on your side
Here is a Slow performance and freezes working in any workspace in Autodesk Fusion that will provide ways to solve this.
I showed where you can change your settings to increase your performance instead of quality and ect...
Again If you get a warning that Fusion is running slowly, you will get a warning that enables you to open a small tab on the right of the screen with on/off choices to help improve performance,
I don't know how else to open it, but I'm hoping @g-andresen can help you there...
Cordialement
Ricky
*Apologies for the bad video quality.
Message 10 of 11
Finally found it...
The graphic diagnostics ensures that you have all the correct peripherals, CPU, RAM to run F360, ect...
but more importantly you can edit your effect settings which can help with f360 performance...
Kind regards
Ricky
Message 11 of 11
othmane
Observer
Observer
I did not get any performance warning.
When I ran the graphic diagnostic the only warning I had was the GPU driver needed an update. I updated it and the warning disappeared but the problem is still there.
Attached are the graphics settings.
For info, I have completely unistalled and reinstalled fusion but still have the problem.
