Bug in Equation Editor
randy1976
Observer Observer
randy1976
Observer
Observer
Will not accept the follow equation when making a sketch (defining a rectangle):
( CameraArmThickness ) * (3 + Tolerance)
Note that I have defined those two variable names and picked them from F360's selection list. However, the equation is colored red (indicating an error) and when I hit enter, it changes the equation to
CameraArmThickness
That is the sum of the problem, but for background, it
* will accept 3 + tolerance as a value
* will also accept ( ( 3 mm + Tolerance ) ) * 3
Note that F360 injected the "mm" into the equation I entered, not me
* will accept CameraArmThickness
* won't accept ( ( 3 + Tolerance ) ) * ( CameraArmThickness )
HughesTooling
You need to cancel the units, you are multiplying 2 millimeter parameters so the answer is in square mm . So something like  ( ( 3 + Tolerance ) ) * ( CameraArmThickness)/mm
Mark Hughes
Owner, Hughes Tooling
HughesTooling
To make this sort of calculation work in all situations you should probably cancel the units for each parameter like this.
Mark Hughes
g-andresen
please share the file for reply
File > export > save as f3d on local drive > attach to post
günther
g-andresen
What is this all about?
If the thickness of the arm is to be multiplied by 3 and then the tolerance is to be added, the expression must look like this:
günther
randy1976
Observer
Observer
Thanks HughsTooling, that worked.
I should say that the decision by Autodesk to implement it this way is completely explicable and very frustrating. To put it mildly.
g-andresen
In my opinion, the user is responsible for controlling the units in equations.
Günther
