BUG: Fusion 360 SVG Import corrupted when paths contain a capitol 'S' command.
saccade
saccade
I was having trouble importing SVG files into Fusion 360, with the results below:
FusionSVGFail.pngOn the left is what the SVG file looks like in the Chrome browser, but on the right is how Fusion 360 imports it. All of the glitches correspond to the uppercase S command used in the SVG <path> definition. It looks like it's interpreting it as a lower case 's' command (relative coordinates) instead of uppercase 'S' (absolute coordinates). The sample file (attached) was generated in Adobe Illustrator.
jeff_strater
@saccade, yes that looks to be a bug with the SVG importer.  We'll take a look at what distinguishes those 3 curves from the rest.
bug:  FUS-45124
Jeff Strater
Engineering Director
saccade
All of the failure cases use a capitol 'S' command in the path (extend curve w/reflected initial control point using absolute coordinates). Curves with the lower case 's' (relative coordinates) work fine.
sameer_babarNJS6C
Hello @saccade ,
I just wanted to update you on the issue(FUS-45124) you found. The development team have now fixed the bug. The fix should be going into the July Release. We would like to thank you again for letting us know of this bug.
Your time and patience are deeply appreciated.
Sameer Babar.
Autodesk Fusion Team.
