Message 1 of 8
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hardware: MBP 2017 i7 16GB ram eGPU RX570
Addon used to generate helical gear (Massive kudos to developer!)
Parameters to generate gear:
- Gear standard = Normal System
- Handedness = Right
- Helix Angle = 40 deg
- Pressure Angle = 20 deg
- Module = 2.5mm
- Teeth = 32
- Backlash = 0.3mm
- Gear Thickness = 5.0mm
Procedure
- Create a gear
- Create -> Mirror
- Select gear
- Select underside face (negative z)
- Save your work
- Modify -> Combine
- Target body = Top gear
- Tool bodies = Bottom gear
- Operation = Join
- New component = Unticked
- Keep tools = Unticked
- Hit OK and then go and do your grocery shopping, Fusion 360 should be still there waiting for you with the spinning wheel of death
Workaround
- Do all the above until you get to combine
- Modify -> Combine
- Operation = Join
- New Component = Ticked
- Keep Tools = Ticked
- Don't go to the shops to do your shopping as F360 hasn't locked up 🙂
It appears something is having an unscheduled disassembly when it goes to delete the tool(s)
