[BUG] explicit joint origin does not derive with the component
TrippyLighting
Consultant Consultant
Message 1 of 8
TrippyLighting
When adding an explicit joint origin to a component and then deriving that component into a new design, this joint origin is not part of that component in the new design.
Replies (7)
Message 2 of 8
karina.harper
Autodesk Support
Autodesk Support
Logged as FUS-47955
Message 3 of 8
lure23
Good.
This bite me again, today. I'll place some pictures here, but just wanting to get a knowledge that is being worked on (it's been in the oven for 8 months, now).
Inner projectInner project
I find this bug and the delay fixing it hard to understand. The Joint Origins are intended to make connecting components easier. The Derive feature is intended to make distribution of components easier. Surely these two should play together?
Workaround: I make a sketch in the inner project (since sketches do survive the Derive) and either create the Joint Origins in the parent side (whoa! bad modularisation!) or join directly to the sketch.
As to Jeff's description elsewhere, this sounds like a "one liner" to have the code also pick up Joint Origins. Is there something more complex involved?
Asko Kauppi
IT guy into Cleantech.
Message 4 of 8
karina.harper
Autodesk Support
Autodesk Support
Hi @lure23
I have added your notes to the internal comments of the ticket. I can't speak to what progress has been made on it, but bear in mind there are thousands of feature requests and changes people want in Fusion. Your feedback is appreciated that this is something people really want.
Cheers,
Karina
Message 5 of 8
lure23
Thanks Karina. Hearing that the number is "thousands" (and considering the throughput times we can see) maybe there is a need for serious reduction of backlog. I feel bad for the developers who need to struggle with such never-ending work pile. Have been there.
Asko Kauppi
Message 6 of 8
TrippyLighting
@lure23 are you fully aware of the difference between Derived components and linked components ?
It might just be that you are better off using linked components.
Message 7 of 8
hpekristiansen
Are there any news about derived joint origins?
I wish that small things like this would take priority over large new functions.
Message 8 of 8
CreativeEngineer
Please add my vote! I would also like to be able to select individual joint origins when not grabbing the whole design at root level. I'm using this to create simplified representations of complex assemblies with lots of fasteners. I pick just the bodies I want, and would also like to grab a couple joint origins that control how the assembly connects to other things.
