Bug: Cycle Component Color for imported part doesn't update viewport
Jemxx
Jemxx
I've imported 2 different parts multiple times. Now I turned on "Display Component Colors". All of the linked parts have the same color.
When I now select all of them, right click and choose "Cycle Color Component", in the browser all the same imported parts have now the same color, but in the viewport they have all different colors (first image).
If I move these parts into a component or from a component to the root of the document, now the viewport updates and shows all the same parts in the same color.
I think this is an update issue of some kind, tested on Windows 10, Fusion 360 Version 2.0.15050 (x86_64).
Cheers from Germany,
Tobi
P-BvanWyk
Good day @Jemxx,
What happens when you change the component color?
PBvanWyk_0-1674558991685.png Bottom of the list.
Does all the relevant components update as intended?
Please click on Accept Solution to help other community members solve their issues.
Also, consider giving a Like to the comments that you feel added value.
Kind regards,
Pieter-Ben van Wyk
Jemxx
Hi @P-BvanWyk,
sadly they don't. The color indicator in the browser adapts as intended, but the viewport doesn't. I've tried a few different things, see the attached gif.
P-BvanWyk
Thank you for the speedy reply,
This definitely seems to be a bug.
I see you are using linked components, do the component's colors work as intended in the original file?
Kind regards,
Pieter-Ben van Wyk
Jemxx
Yes, when I break the link of all components the component's colors works as expected (they are all different in the browser and also update the viewport accordingly).
Then I need to wait until this gets fixed, because ideally I want components to get the same color (for easier identification).
P-BvanWyk
Thank you for the additional information 😁
I'm sure this will narrow down the search for the development team.
Kind regards,
Pieter-Ben van Wyk
Jemxx
Any updates? The issue still persists, and I can't continue working on my project.
It would be nice if someone official could at least acknowledge this issue...
