Bug? Coincident constraint not working on endpoint of offset line
GRSnyder
Message 1 of 25
GRSnyder
Take a look at the attached file. Your mission is to make the lower endpoint of the arc coincident with the right endpoint of the lower (offset) line by applying a coincident constraint.
It initially seems to work. But in fact, the arc endpoint ends up constrained to the lower line, not to the endpoint of the line. To see this you can either select the coincident constraint and see the entire line highlight, or you can drag the construction line up and down to demonstrate that the arc endpoint is easily separated from the end of the line.
This is consistently reproducible.
Replies (24)
Message 21 of 25
rohit.bapat
Hello All,
This is certainly a defect. I have created a ticket FUS-153888 for team to take a look at. I believe the original workflow shows a defect which upon fix will address the coincident constraint issue.
Rohit Bapat
Sr. Product Owner
Message 22 of 25
samuel.templeUCPAE
Thank you all for your input in regards to this issue.
certainly see 2 issues in this workflow
  1. Point to Point coincident is not honored
  2. End point of offset line is gone on drag
A ticket has been created and this is now being investigated by our development team.
FUS-153888
Samuel Temple
Senior Software QA Engineer
([email protected])
Become an Autodesk Fusion Insider
As a Autodesk Fusion Insider, you will have early access to next official version of Autodesk Fusion, several weeks before it is released to the general public.
Message 23 of 25
HughesTooling
@samuel.templeUCPAE Would you mind looking at this post please. It has a similar problem with an arc.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
Message 24 of 25
samuel.templeUCPAE
Hello @HughesTooling
Thank you for letting me know. I have sent this to my development team for them to take a look at it.
Samuel Temple
([email protected])
Message 25 of 25
CGBenner
@GRSnyder @rohit.bapat @samuel.templeUCPAE @HughesTooling
Marking as solved, but please feel free to post with any new information, or when the ticket gets resolved.  🙂
Chris Benner
