Browser window float/detach + add option to create columns for people using multiple monitors
WesleyTack
WesleyTack
This is a shout out to all multiple monitor people. I'm pretty sure I'm not the only one who finds it frustrating that the scrollbar is very thin and annoying to select and drag, especially when you already have a lot of objects selected and you accidentally press next to the scrollbar you have to re-select everything again. This scrollbar thickness being too small has been mentioned in the past here, Autodesk doesn't fix this sadly or finds it a priority.
Another annoying thing is navigating the browser when a file becomes bigger and bigger.
A fix for these two issues would be to detach the browser window (which is an option I know), but also make it so that the detached window becomes it's own Windows explorer type window and shows all components in columns. See the example below. I also doubt this would be a big fix/addition to add for the Autodesk developers and it would be a mayor help for many users I'm sure (hopefully the replies here will be an indicator for this and rise awareness).
This would allow for quick selection of components and really speed up the workflow tremendously.
Sincerely,
- Wesley
lance.carocci
Thanks for the feedback on the browser experience, @WesleyTack! I will pass this along to the appropriate team, including the note about scrollbar width.
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
