Browser window doesn't stick to Fusion
fheidinga
fheidinga
When I use Fusion in combination with other apps like Safari and I switch between desktops, Fusion's browser after a while remains stuck on another desktop window. I use a 2018 15" MacBook Pro.
As a workaround I hide the browser, make it visible, drag it so it becomes a window by itself and then attach it to the Fusion window again. Until the issue happens again.
Easiest way to prevent this from happening is not working with any other programs than Fusion...But still. working with other programs besides Fusion would be nice....
RajkumarIlanchelian
@fheidinga We are aware of this issue and it is a long standing problem that we are actively looking to resolve. It is the spaces that is causes this problem. If Fusion is operated in a non full screen mode then this will not happen. AS I called out we are certainly looking into addressing this.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
fheidinga
Thanks for the fast reply! And as I said, the issue is manageable -staying in the same space and not too much switching between apps (which is generally good for focussing anyway for a ADD type person like me 😉 ...).
d
