Break view (in Drawing environment) dimensions are not correct.
m629312611
m629312611
I am having problems with the Break view (in the Drawing environment), the dimensions are not correct, but they were before.
I am trying to dimension a series of slots along a beam that doesn't fit on my page, so I break it at multiple points as I have done on other pages, but this time the dimension in between slots is not correct.
Any ideas about why this is happening now?
jhackney1972
Please attach the MODEL you created the drawing with.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
jhackney1972
While I was waiting for your model, I did a bit of testing.  If I create a Break View and apply a Center Mark Patten, then the dimension command DOES NOT function correctly across the break line.  Video and model are attached.
@jeff_strater, I hope you can take a look at this and tell me it is a Fusion issue or I am doing something wrong.
(view in My Videos)
jhackney1972
There was no response from Autodesk personnel so I would like to resend a notice to @ClintBrown3D and get your comment on this problem.  Please see the original message and my post with the example and video.  Thanks
liang_chen
I can reproduce this issue when create dimension on center mark pattern. It has been reported as internal ticket for fixing. The DID is FDWG-18607.
Showing as attached video, this issue happens on center mark pattern, and the dimension works on dimension of individual center mark and ceter of hole. Before the fixing, it could be a workaround. Thanks
Fred Chen
SQA Engineer
Quality Assurance Team
Autodesk, Inc.
