Boundary Fill
Boundary Fill
Boundary Fill
I am attempting to use a boundary fill to remove the hollow section from this cylindrical tube. However when I use boundary fill and select the cells the body remains hollow, what is the issue?
TheCADWhisperer
Use Delete face instead.
Here is the file. The profile I am trying to fill is in the goal posts.
dsouzasujay
@Anonymous ,
What is the final output that you are looking for?
If your goal is to make this hallow cylinder to solid, then please follow below video.
Video 1:https://knowledge.autodesk.com/community/screencast/40530d4b-2f33-43b6-b7e1-2bf22b8c346c
Video 2:https://knowledge.autodesk.com/community/screencast/2256c60b-e371-469f-895f-0989be6936dc
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
