Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
BOM not updating and properties locked
info7JY2S
Message 1 of 18
info7JY2S
In a design I created 2 weeks ago, I added a component today. When I try to edit the description of this part it is greyed out and locked. Also the component doesn't show in the BOM function under the management tab.
I am the only user with full Admin rights. also collaborations appears to be working (as checked in the online hub)
In the online BOM the component doesn't show up either.
Replies (17)
Message 2 of 18
pavithra.anjanappaZDLCY
Hi, Could you please share the screenshots/recordings which shows editing is locked?
Message 3 of 18
navya_gelli
Hi @info7JY2S ,
I wanted to check in and see if you saw @pavithra.anjanappaZDLCY follow up questions and if assistance is still needed or if you found a solution to your question already? Please share any available information so the community can assist you further.
All the best,
Navya | Community Manager
Message 4 of 18
tomJSPUS
I'm having same issue.  I understand that if I need to change the description of a 'external component' used in a model, I should open the model of that specific component.  Make changes to description there.  Once tho component is saved, I should be able to sync or update the model using that component and it should then reflect the change.
However, I can't make the description change in either of the 2 models.  They are both locked.
How do we made these fields editable again?
Thanks, Tom Davern
Message 5 of 18
info7JY2S
Here are 2 screenshots of the problem. The new part is not showing in the BOM
Message 6 of 18
Thank you Navya, Tom,
Will be bringing this issue to the respective team's attention for further investigation, meanwhile could you please the hubid?
Thank you,
Pavithra Anjanappa
Message 7 of 18
tomJSPUS
I'm sorry but I don't understand the last part of your statement or request.
"meanwhile could you please the hubid?"
Can you please clarify?
Thanks, Tom
Message 8 of 18
xianhua.chen
Hi @tomJSPUS and @info7JY2S ,
Thank you reporting this issue, please open the design which you encountered into this issue, then go to File -> View -> View Text Commands, input 'data.p' and enter, then share with us all the respond texts. Thank you.
Xianhua Chen
PDMS Quality Assurance Team
Autodesk, Inc.
Message 9 of 18
tomJSPUS
This file was created recently (2 weeks ago).  It was correct with component descriptions which I use in the parts list of a drawing.  Now, the parts list is void of description on the drawing.  The components within the model driving the drawing are also void of description info, plus the field is locked.  They are all 'internal components' used only within that model.
Also, the properties dialogue box looks different.
Data.p output below
data.property
------ Hub Info ------
Hub Id: generalpallets
Space Collection: co.klwDSwALRHO8yN69nKSlzQ
Tenant Id: 14636925
Hub Root Folder: urn:adsk.wipprod:fs.folder:co.c4kaq-PbSY2_dLX_gYwhMw
FCE Id: urn:adsk.fusion:scope:8af3daca-6a04-4c63-808a-b52e01abedab
Forge Id: a.YnVzaW5lc3M6Z2VuZXJhbHBhbGxldHM
Owner Id: N2RNJED2PKE7
Entitlement Type: SUBSCRIPTION
Hub data version: 2.0.0
Opt in Status: enabled
Is client compatible: true
------ Current Doc Info ------
Doc Display Name: KM LBV-1 26 x 26 x 5 3/4
Lineage Urn: urn:adsk.wipprod:dm.lineage:6ITdQt0MSJy_SH_vohy30Q
Version Urn: urn:adsk.wipprod:fs.file:vf.6ITdQt0MSJy_SH_vohy30Q?version=1
Parent Folder Urn: urn:adsk.wipprod:fs.folder:co.mT3o7kM0SDaGPGwOV-3gxQ
------ PIM properties ------
Version Snapshot: AxbpK5SMovw2ppThjsBq1N
Root Product: HH4UIIH7Yp0ui2DUMDjme3_aga
------ Custom properties ------
DesignModelRevisionID: 74437b0f-0f97-4437-9216-b2c340ca6cb0
EIPContext: {}
pimDMAction:
thumbnailStatus: REGISTERED
LibraryMemberItemInfo:
------ No custom flags!
End of data.p
Message 10 of 18
xianhua.chen
Thank you Tom, we are looking into the data you reported, will update you once we have further findings.
Xianhua Chen
Autodesk, Inc.
Message 11 of 18
xianhua.chen
Hi Stefan,
We are looking into the issue you reported as well, could you help share the loca logs with us by command Help ->Support and Diagnostics -> Diagnostics Log Files. It might take a while to collect the log file.
Xianhua Chen
Autodesk, Inc.
Message 12 of 18
xianhua.chen
Hi Tom,
Looks like the 'data.p' response you shared is different from the screen shot you provided above. It says "Doc Display Name: KM LBV-1 26 x 26 x 5 3/4", while in you screenshot, it is "MRO C-7 XXX".  Could you open "MRO C-7 XXX" and share the 'data.p' response again?
Or open this file, then dump the local log file to us by command Help ->Support and Diagnostics -> Diagnostics Log Files
Xianhua Chen
Autodesk, Inc.
Message 13 of 18
tedavern2
My apologies.  I have issues with every drawing I open or create, to varying degrees.  In this example, most components have editable description fields.  the multiple occurrences of the "1x6x84" are not editable.  It is an external link and if I open that external model, the description is not editable there, either.  Below is the data.p info from this MRO C-7 XXX model.
data.property
Tenant Id: 14636925
Hub Url: https://generalpallets.autodesk360.com
Doc Display Name: MRO C-7 50x84x9
Lineage Urn: urn:adsk.wipprod:dm.lineage:-vBbVd0kScewJdLO1nvUEg
Version Urn: urn:adsk.wipprod:fs.file:vf.-vBbVd0kScewJdLO1nvUEg?version=5
Parent Folder Urn: urn:adsk.wipprod:fs.folder:co.KVNrInqHTYiBqvrqk_EU2g
Version Snapshot: fmyPGULwYKvNMiq3bWUFb0
Root Product: 509cnR5wQ50lO0R7XWW0lf_aga
DesignModelRevisionID: 6f236e6b-9db1-4947-aed7-a17e324f7e4f
EIPContext: {}
Message 14 of 18
xianhua.chen
Hi Tom,
The backend data looks good, to know what's going wrong exactly, we would like to access your design. Would you mind invite one of our engeerning team member into your project to take a further look? I will send you a private message to provide the emails address.
Xianhua Chen
Autodesk, Inc.
Message 15 of 18
tomJSPUS
I would welcome sharing my files.  Where should I find the private message for the invite information?
Also, is there a way to have communication with someone more near my time zone?  I am in Central Standard time of the US.  Currently, I get 1 exchange per day because of the time difference.
thanks, Tom
Message 16 of 18
xianhua.chen
Hi Tom,
It is in upper right Mail icon. And our engineer is in US timezone.
Xianhua Chen
Autodesk, Inc.
Message 17 of 18
tomJSPUS
Have not yet received an email to share with.  Should I have?
Message 18 of 18
xianhua.chen
Hi Tom,
Looks like you replied the thread with two diifferent count, I sent email to another one. Let me send it again.
Xianhua Chen
Autodesk, Inc.
