- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a 3D mould that I have created in Fusion 360. I've had it 3D printed, and now wanted to use Fusion 360 to tell me the volume of the part I'm moulding when I'm mixing the resin to go in the mould.
This should be really simple. I used the combine-cut command, while keeping the tool (the mould model), to create the moulded form inside. Then I right-clicked and selected properties, however the properties are blank?
The component has one body and it's a solid body, rather than a mesh or a surface, but it only tells me an area and the density of the material I have selected, rather than a volume?
I've tried going back and recreating the form in a different order but it doesn't seem to change anything - the combine command seems to zero the volume every time, even though the volume of the target body beforehand is 40,300mm3 and the tool body is 19,880mm3, so the result should be 20,420mm3?
This happened to anyone else? Is it a bug that Autodesk are aware of, or is there a work around (aside from my calculation above)? I've obviously got what I need now, but was curious.
