- Mute
- Permalink
- Report
I've searched quite a bit but it's difficult to find a search term. I created two bodies from separate sketches which are perpendicular. most of the faces are perpendicular as expected but if I inspect two faces on one side it shows a very small angle between them. I've tried deleting the feature and re-doing it and I've completely re-created the second sketch but I can't find where the discrepancy is coming from and its always in the same place.
The first picture shows the weird angle, the second is as expected and all the other three sides show the expected 90 degrees and the bodies themselves all measure as expected.
I appreciate the error is tiny but I think it's causing problems later as I add to the complexity of the design and start getting weird issues where extrusions don't match up properly or lofts refuse to recognise the face is in the correct plane.
I'm guessing its a rounding error related to the view because the measured angle changes if I rotate the model (third picture) but if someone can spot a schoolboy error I would be grateful
