Blank white workspace
When I open a model in Fusion 360, it does not appear in work-space except the data panel. Tried all the solution recommended in the community forums, no success yet. Tried clean uninstall, reinstalled, tried to run with graphic processor, everything failed.
If anyone can help! or facing same issue?
TheCADWhisperer
Do you see this behavior with only this file?
If  you start a new file - do you see this behavior?
If you reboot the computer - does this behavior persist?
If you click Home, does this behavior persist?
If you hide all but one component and click Home, does this behavior persist?
If you expand that one visible component and turn on the visibility of the Origin, does this behavior persist?
Can you save a copy of the file, delete  all but one component, turn on the visibility of Origin, Expand the Bodies folder, Expand the Sketches folder. Make sure all are visible, capture a screenshot and post the image here?
Can you File>Export and then Attach the *.f3d file here for others to test?
lance.carocci
@TheCADWhisperer is asking everything I would have - but here's a few more:
Have you done any graphics overrides to Fusion 360, such as messing with display scaling overrides in Windows, or 3D performance/quality sliders in Nvidia drivers?
How are you connected to your display? Is this internal (laptop), through a dock (especially if it says DisplayLink instead of Thunderbolt), or direct to the device's GPU?
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
