Hello Mike,
Thanks for taking the time to make a Screencast video for me. Yes, exact same workflow. And btw, you can call me Kostas.
I am having a lot of trouble with my Sheet Metal. First I tried to make a new rule on my laptop (Windows 7) and it didn't make it and then erased all my rules from the library. Then I used Fusion on my PC (Windows 10) and had all the default rules and stuff, but when I tried to work on the project that the problem occurred I ended up losing my rule library on my PC as well.
After all this, I made new rules from the one in the "In This Design" portion of the Sheet Metal Rules dialog, but that means I currently have rules only for Steel. Now, the project in question is an assembly that has imported Solidworks parts, imported Inventor parts, step files, Fusion360 models and Fusion360 Sheet metal models. One of the Sheetmetal models is a mirrored component of another Sheetmetal model with a big 36mm clearance hole deleted (selected the face and deleted it).
The problems started when I tried to make a drawing of the mirrored part. It gave me the table of the original part. That meant that the direction of the bends was noted in the reverse ("mirrored") direction. And from then on it would only give me the table of that original Sheetmetal part. I have parts with only one bend and it gives me that same bend table with the 2 bends.
P.S. You can find a different forum post where I discuss the Rule Library issue. Still unsolved, though...
