Looks like I have encountered a bug in flat pattern dxf export.
Here is a simple sheet metal part copied from a bigger assembly: https://a360.co/2K5BTfa . Everything works fine when you activate that part's flat pattern and then export it as dxf - you will see two bend lines. But if you try to recreate the flat pattern (delete it and then create a new one) you will see only one bend line in the exported dxf.
Actually, I had to save that part to a separate file to get a correct dxf. It shows only one bend line when exporting directly from the original project. And this trick fails with another part - https://a360.co/2ytgDyB . I couldn't find a way to export it with all the bend lines included.
