Auto dimension / constraint of sketches
hansvaneven
hansvaneven
Hello
is there a possibility to accelerate the constraint of your sketches, or an automate process for this ?
Some complex sketches can take a while to constraint so this is something that could be of help, I know you can do that in the drafts but something like this in the sketch itself would be great, thanks
g-andresen
How should the application “know” which dimensions you want to assign to the elements and whether they should be perpendicular, tangential or co-linear to other elements, for example?
günther
hansvaneven
Good question but why is this an option then in the drafts space ?
g-andresen
This is because in drawing mode you adopt the dimensions that were previously defined in design mode.
günther
