Assembly Uploads from Vault to Fusion Team Hub Incorrect
When I initially do a project upload from Vault to FTH, most assemblies are missing part references, and only partially complete. Which assemblies have issues and which parts in those assemblies are missing is completely random; there's no consistency in which assemblies are incomplete when doing an initial upload. Their part files are uploaded fully and correctly, however they just aren't referenced. The only way I can currently fix this is by checking the assembly out and back in in Inventor, then reuploading it to FTH. But since we have large amounts of assemblies and want a scheduled upload, this is not an actual solution for us. After trying this numerous different ways, it does not seem as though there is an issue with our assemblies (which is why I have not included an assembly file), but rather an issue somewhere else down the line. If anyone has had similar issues and has some advice I would greatly appreciate you sharing it. Thank you.
johannes.bauer
Autodesk Support
Autodesk Support
Hi @Anonymous,
If it is fixed by checkout/check-in from Inventor it could be, that the files have been added through drag and drop and references have not been capture correctly from Vault.
I would suggest you open up a case.
Support can work with you to find the reasons.
HTH
-Johannes
Customer Technical Success
