As usual
As usual
hjartland
As usual
hjartland
IDK what you 'fixed' this time, but ...
I'm trying to Extrude the face on the Lower Right. But Fusion in its finite wisdom. Has an obsession with Extruding only the face in the Upper Left. Why!? I hit Escape over and again. Even hide the body is springs from. Yet ...
g-andresen
Upload the file to take a look.
günther
wmhazzard
If that is a sketch in the left, then extrude will default to that. Just deselect it in the dialog box and select the face of the body.
TheCADWhisperer
You have two choices:
Choice 1 - use Press/Pull rather than Extrude.
Choice 2 - if you do not choose Choice 1 and you do Extrude, then Ctrl (on Windows, or equivalent on Mac) unselect the sketch and then click the body face.
Uhm, IDKM-
and Choice 3, Edit the original sketch for the body or the original Extrusion feature.  (I now suggest that should probably be Choice #1.  Attach your *.f3d file here and end all doubt.
