ARRAY TOOL
ARRAY TOOL
ARRAY TOOL
I have not found the Array tool in the Sketch menu. Is there this tool in Fusion 360?
masa.minohara
Hi @Anonymous,
Thank you for posting in the community forum! I believe constraints and dimension tools help achieve what you need and the videos below contain helpful information.
Also, the tutorials here would be helpful too.
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
davebYYPCU
In Sketch mode it is called, Rectangular / Circular Pattern, in the lower half of the Sketch Menu
and it is not recommended that you use them, unless very simple geometry
(often big performance lags - every constraint and every dimension is recalculated on every edit)
if you can use the Pattern Tools for features or bodies in the modelling area - much better.
Might help....
