ARRANGE feature multiple object select problem
Fusion360Hodad
Message 1 of 10
Fusion360Hodad
Fusion360 v2.0.8809
macOS v10.13.6
When using the ARRANGE feature, I am unable to select more than 1-Object (body) which defeats the entire purpose of using the ARRANGE feature for layouts.
The Shift or Command key has no effect when selecting objects in the ARRANGE feature as only 1-Object (body) can be selected.
If multiple Objects (bodies) are selected prior to initiating the ARRANGE feature, then the ARRANGE feature changes the selection to only 1-Object (body) selected when the ARRANGE dialog box appears. No more than 1-Object (body) can be selected.
Replies (9)
Message 2 of 10
jhackney1972
Are you sure you have the "Type" select set to the entity you desire, in this case Body?  Please create a Screencast showing this issue with all picks and clicks.
John Hackney, Retired
Message 3 of 10
Fusion360Hodad
There is no “Type” select option in the ARRANGE dialog box. I am selecting Body types for the Objects. Oddly it will allow the selection of 1-Body and 1-Sketch for 2-Objects selected, but not more than 1-body.
Message 4 of 10
jhackney1972
You need to send along the Screencast to show what you are truly doing.  I have the feeling we are talking about two different Array commands.  I showed you the Model Array command dialog in my last post, are you in a "sketch" array command?
Message 5 of 10
davebYYPCU
Probably not,
Arrange is a Manufacture command in Preview.
Message 6 of 10
jhackney1972
Thanks @davebYYPCU , I was reading Arrange as Array. @Fusion360Hodad  sorry for my misreading of your post.  The Arrange command, in the Manufacture Environment, only works with Components not bodies.  That could be your issue.
Message 7 of 10
Fusion360Hodad
Yes, that makes complete sense! That said, it seems counter-intuitive that the ARRANGE function allowed me to select a Body and/or a Sketch object, if it only works with Component objects. Converting Bodies to Components resolved the issue. THANKS!
FEEDBACK to Autodesk:
a) Need to clearly communicate that the ARRANGE feature only works with Component objects if that is in fact the case.
b) Given "a)" above, need to code the ARRANGE feature to not allow the selection of Body and/or Sketch objects, and provide error messaging feedback that these object types cannot be selected and that a Component type object must be used with the ARRANGE feature.
Message 8 of 10
AmyLiu
@Fusion360Hodad ,
thanks for your feedback, I understand your point about Body v.s. Component, which sometimes did have confusion.
you're right, Arrange based on Component, but in fact the selected object is body or sketch inside Component.
here we didn't filter out body level, because the case for one component with multi-bodies(for example, body A, body B, and bodyC), just select component couldn't meet the requirement if user wants to Arrange bodyC; select component will arrange the 1st body(body A) by default;
hope it helps.
Amy Liu (cui.liu@autodesk.com)
Senior Software QA Engineer
Message 9 of 10
Fusion360Hodad
The Body was not nested inside a Component object. It was a stand alone Body object.
Message 10 of 10
AmyLiu
I might not explain clearly. attach a snapshot
when do Arrange, select object, if selected component have more than one body, user has the ability to switch body as they wish, either body inside component(but only one body inside one component) could be selected to do Arrange. that's the reason we didn't filter out body selection when using Arrange command, although the selection is based on Component level.
This is to explain per your feedback:
