Arms of glasses don't move even when I have a rotation joint.
bgreens2
bgreens2
I have 2 cylinders in which the arms of the glasses are connected via a joint. These cylinders are connected to the frame of the glasses via a rigid joint. I cannot move the arms about the rotational axis of the joint. Please Help
KristianLaholm
You need to Ground one component of the assembly.
Right click the component in browser (in your case the center frame) and select "Ground".
bgreens2
Thank you!
