Archiving of a Folder-level project resulted in losing permissions reoccuring
jri6
Message 1 of 19
jri6
I've had this issue in the past and it appears to be specific to folder-level projects. When attempting to unarchive a FLP, the project doesn't unarchive and permissions are not restored (including admins). The admins thus lack the permissions to resolve the issue thus leaving project completely inaccessible. I was informed that the issue was reported internally as ATEAM-39294 and was subsequently fixed, but the issue's returned.
Replies (18)
Message 2 of 19
porkodi_autodesk
Our development team has resolved the issue with your data. Please can you confirm on  your end if you are able to access your project/ data?
Thank you!
Porkodi Nathan
Message 3 of 19
jri6
Yes, the issue has been solved. Thank you.
Message 4 of 19
clief_castleton
I have had the same issue today. Are you able to help?
Message 5 of 19
porkodi_autodesk
    Just a few questions to make sure I understand the problem.
  1. Are you not able to unarchive a folder level project?
  2. Are you able to unarchive a folder level project and permissions are not restored in the project?
Thank you!
Porkodi Nathan
Message 6 of 19
clief_castleton
The latter. I was able to restore (unarchive) the project folder. I cannot restore the permissions. Thank you.
Message 7 of 19
17bucolocDWRDX
Observer
Observer
I have the same issue I believe. I cannot unarchive my project and it has now disappeared from both the active and archived sections.
Message 8 of 19
clief_castleton
Please let me know if you find a solution and I shall as well.
Message 9 of 19
porkodi_autodesk
Thank you for reporting the issue. We have reached out to the development team. We will keep you posted on the progress.
Thank you!
Porkodi Nathan
Message 10 of 19
porkodi_autodesk
    When you  restore (unarchive) the project, you cannot restore the permissions - This is by design.
Thank you!
Porkodi Nathan
Message 11 of 19
Korvax_
Observer
Observer
(Resolved)
I tried to restore a folder-level project in Fusion Team Hub. During this process, an error occurred ("Something went wrong, please try again later"), and now the project is gone from both the "All Projects" and "Archived" tabs. As I do not have a local copy of the project, all files are completely gone and inaccessible to me. Is this similar/related to the issue of this post, and if so, is there any way to resolve it? If relevant, the missing project name was called "Farnwerk." Any help would be much appreciated. Thank you.
Message 12 of 19
Ron_Young
All of my archived projects are no longer visible/able to be accessed. This is alarming.
Message 13 of 19
Ron_Young
That exactly the situation I have, including that error prior to their complete disappearance.
Message 14 of 19
porkodi_autodesk
Thank you!
Porkodi Nathan
Message 15 of 19
porkodi_autodesk
Hi @Ron_Young ,
  Our development team is looking into the issue. We need more details:
  1. What is your hub Url?
  2. What is your email id?
Thank you!
Porkodi Nathan
Message 16 of 19
Ron_Young
https://outlook27632.autodesk360.com/g/all_projects/active
and of course
https://outlook27632.autodesk360.com/g/all_projects/archived
empty
Which it remains, even if I this minute make a new test project and then archive it, it vanishes and is not visible, lost in the ether.
My email ID? You mean the address you emailed me at? The one and same.
Over a week to respond, lucky I don't rely on this data commercially.
O HOLD ON A MINUTE!!
It is very fortunate I had downloaded all 10gb to local storage isn't it.
That way at least I could work on it in another non cloud application that IS reliable.
At this point I frankly don't care if don't/can't restore my missing data as I know from this that your backend simply can't be trusted. You do need to fix the vanishing archives though, because I imagine, I'm not the only one.
Message 17 of 19
Ron_Young
For anyone else playing along.
This python tool can insure your file integrity by allowing you to take control of your own IP rather than leaving it up to a third party.
https://github.com/Jnesselr/fusion-360-total-exporter
Message 18 of 19
porkodi_autodesk
Our aplologies for the inconvenience caused here. Our engineering team is aware and is working on a resolution to this problem.
Your data has been fixed. Please can you confirm on your end if you are able to access your project/ data?
Message 19 of 19
Ron_Young
Yes they have reappeared, restored from a backup no doubt, what date? who knows.
I have just completed deleting all of them, as this incident, along with the previous broken links fiasco has made it painfully obvious that this tool, or rather it's backend infrastructure, and it's management simply cannot be relied upon for MY DATA.
The grand cloud to rule them all experiment is simply inadequate and unfit for purpose, you can't be trusted. I now have the very minimal footprint of files in your system and will keep it that way while I look at transitioning to someone elses CAD solution.
