April 2026 Fusion Update - Start-Up Navigation Issue
al_walker
Message 1 of 27
al_walker
I have Default Design Type set as my Start-Up Experience with Hybrid set as the the Default Design Type and on Start-up that's exactly what I get without the Intent-Driven Design Window, so thanks very much for fixing that.
I then open an existing design and I no longer see the Autodesk Assistant on the right, so thanks again for removing that.
However, when I close the existing design I am navigated back to the Home page, rather than to my default Start-Up Experience, which is not what I specified in Preferences. I don't like the Home view as it's really unstructured, so don't use it.
My preferred method of navigation in my Hub is via the Data Panel, and that's what I want to see by default, per my Preference settings. I have to create a new design to get the Data Panel view.
On closing a design I want to go back to my Start-Up experience blank Hybrid design without the Intent-Driven Design window, that also displays the Data Panel.
So kind of two steps forwards, one step back. Can this navigation issue be fixed please?
Kind regards,
Al
Replies (26)
Message 2 of 27
al_walker
I just had my Default Design Type spontaneously change to Part Design, so another issue to sort out please
Message 3 of 27
bwalker145
Agreed, the previous experience was better.
They removed the "What do you want to design?" at start-up, but now it you get to see it every time you have to start a blank design just to browse the standard Data Panel. One step forward, two steps back...
Message 4 of 27
bbtfabrications
Agreed, the home tab has cost me more headache and time this week than I care to mention.
Nate Schaub
CAD Designer/Machinist
BBT Fabrications
Message 5 of 27
jlarsonLP454
I just updated Fusion and opened it for the first time. Went to open the data panel by clicking on the location of the data panel icon (didn't look at the icon before clicking since I do it by muscle memory) and now there's a home button there instead. Once Home is open, I can't close it by clicking on the button again, and the data panel button is greyed out. This is a terrible user experience, much worse than the previous annoying "what do you want to design" pop up.
Apparently I have to create a part to get the data panel back so I can open an existing part file? Please give me a startup option to start in a blank screen with the data panel open - that would be perfect. Or at least go back to the original UI before you added the "what do you want to design today" popup.
The home screen is a chaotic mess that is useless to me.
Message 6 of 27
bentwookie
It's confusing for sure
1) Open a file
2) Click that home button in the tab bar
3) Try to get back to your file. It's oddly not obvious where to click.
The home screen presents as a tab, in that it replaces your open document and displays in that space, but it doesn't draw its title as a tab. It's toggle from a place that historically has come in from the side, but goes essentially window-modal. Pick a lane Home Panel!
They'll always need to be something like the data panel which comes in from the side, as you have to be able to use with an open document (to import all these parts I'm now forced to create), so a window-modal Home screen is the odd man out.
IMO, the data panel should look like it does when in a narrow, portrait aspect and then convert to something more home-screeney when wider. Have a button in the data panel that toggles it.
(and then fix all the pixel-peeper bugs in that panel. Heaps of alignment problems, buttons atop other controls, inertial scrolling broken by slow reload on the main thread, on and on...)
E: I spent some more time in the Home screen. What a mess
  • Search still...can't
  • Scrolling the project list just stops
  • Everything is slow slow slow
  • Disclosure triangles for projects that then tell you they're empty when you turn them
  • With all this room, still no way to organize. No drag and drop. There's less functionality here than the data panel
  • No indication that opening is opening
The wheels are flying off this product.
Message 7 of 27
scottprater
I want to upvote this post a thousand times.
Autodesk, PLEASE don't make arbitrary changes to workflows WITHOUT DOCUMENTING IT in the patch notes.
For what it's worth; yes, the data panel is a much better experience then the home panel (which I almost never used until now). The home panel is slow, clunky, difficult to navigate, and I would rather do anything I wanted to do in the home panel on a web browser (which is a much better experience).
When I close out of all my designs, I literally have to create a new part just so I can navigate through our design hub.
-Scott
Message 8 of 27
MikeSmell_ADSK
Hi all - Thanks for the feedback on this topic. I will digest each of your feedback with the team closely, but I will provide some clarity to help you all get moving, hopefully a bit faster through this change.
We do have an option to control the startup behavior, as documented here - https://www.autodesk.com/products/fusion-360/blog/april-2026-product-update-whats-new/#usability. Your startup behavior should not have changed. If you previously went to the Home tab on launch, you should still go to Home in the new release, but with no document open. If you previously went to a default blank document on launch, that should remain unchanged as well.
There is a change in the last document close that cannot be changed. You are now returned to Home to the last panel you were currently on. For example, if you opened a document from Projects, you will return to Projects. If you are more comfortable navigating from the Data Panel, you can still do that before closing the final document. Control+N is a keyboard shortcut to get you a new, blank document to help you quickly get back to the data panel.
Message 9 of 27
al_walker
Hi Mike,
Thanks for coming back, I suggest the navigation rule is quite simple: When the last document is closed, Fusion reverts to the user's preference for the Start-Up Experience with the Default Design Type. If a user wants to start a new design of a different type, it is available from the File drop-down menu. That way a clean and clutter-free workspace can be maintained.
For those users who want to use the new features, they can choose to do so, and for those who want Fusion to behave the way it has historically, they can choose that experience.
That way everyone is happy.
I would also suggest that as many users have evolved personal workflows over a period of years that future changes to the Fusion experience should always allow for the 'classic' experience to avoid alienating such users. What may be genuinely seen as enhancements by the Fusion product management and development teams cannot take into account the myriad workflows that users employ on a day-to-day basis, and indeed are often fundamental to their commercial livelihoods and the business services that they offer.
As someone who has held senior corporate product and engineering management roles, I learnt long ago (the hard way) that users' workflow requirements should be the driver of product evolution, and not perhaps the internal corporate view of what it should be.
Kind regards,
Al
Message 10 of 27
dixonjn
Hate the new UI - why has it been forced on me - getting really sick of Fusion 360 and the stupid design changes
Message 11 of 27
MikeSmell_ADSK
Hi all - Thanks for the feedback. Please see my update from today in this thread. We are working on a refinement to the behaviors associated with this change.
Message 12 of 27
MikeSmell_ADSK
Hi all,
Please see my latest updates on Home behavior here.
Mike
Message 13 of 27
al_walker
HI @MikeSmell_ADSK
Thanks very much for listening. I'm sure I'm not the only user who would prefer to see a full focus on bug fixes instead, especially the numerous outstanding ones with Fusion Electronics that I've reported (just ask Jorge Garcia). The only new feature I want is the addition of a square/rectangle through-hole pad so I don't have to carry on with the old EAGLE polygon shape workaround.
Kind regards,
Al
Message 14 of 27
al_walker
Hi @MikeSmell_ADSK
Can I also share with you please that previously fixed issues with Fusion Electronics are being reintroduced on subsequent releases:
https://forums.autodesk.com/t5/fusion-electronics-forum/polygon-pour-slow-in-latest-update-fusion-26...
Kind regards,
Al
Message 15 of 27
MikeSmell_ADSK
Hi @al_walker -
I will pass this along to our Electronics team and ask them to share an update here.
Mike
Message 16 of 27
al_walker
Hi @MikeSmell_ADSK
Thank you for your time and consideration.
Kind regards.
Al
Message 17 of 27
melisa.kaner
Hi @al_walker ,
Mike kindly tagged me in here, I lead product management for Fusion Electronics. I just wanted to quickly jump in and acknowledge that we're taking a look at the issues you flagged here and in the linked threads. Our QA will be reaching out very soon. Thank you for taking the time to reach out, I can totally understand the frustration if bugs are being re-introduced - we really appreciate your patience while we check this out.
Best regards,
Melisa
Melisa Kaner
Principal Product Manager - Fusion Electronics. Please DM me for Fusion Electronics feedback!
Message 18 of 27
al_walker
Hi @melisa.kaner
Thank you very much for your response. As there are quite a few outstanding issues, in addition to the two that were reintroduced, I would appreciate the opportunity to compile them in one place, so that you can have visibility of all of them rather than having to hunt through forum posts, with the risk that some might be missed. There are also some low-level issues that I haven't yet reported due to these other ones not being resolved.
Kind regards,
Al
Message 19 of 27
melisa.kaner
Hi @al_walker,
That would be fantastic! We all really appreciate your time here - thank you.
I've just spoken with our internal team and @ajay_krishna_t_s is leading this investigation internally. Tagging him in here to follow up directly.
Best regards,
Melisa
Melisa Kaner
Message 20 of 27
ajay_krishna_t_s
Hello @al_walker  ,
Thank you @melisa.kaner for adding me to the thread. @al_walker , I have sent you a DM. Can you take a look at that and get back to me? Thank you.
Best Regards,
Ajay Krishna
Software QA Engineer
