Any Local Computer File Dialog does not appear, if most recently used path (drive) does not exist anymore
Some days ago I used a directory from a virtual drive (which is manually mounted on demand) to store some export files or some 3d-printed stl files.
Today I wanted to open some file from my local computer, but the file open dialog did not appear at all.
Then I tried to export some stl file for 3d printing. Same effect: save file dialog did not appear.
After experimenting some time I found out, that all the dialogs came back to work when I mounted the drive,  which I had recently used.
HughesTooling
This is a known bug there is a manual fix in this post@matt.pooley  Guess this bug's still not been addressed? Still comes up one or two times a month.
Mark
Mark Hughes
Owner, Hughes Tooling
