- Mute
- Permalink
- Report
Hi all.
as the tittle says, Yet another DXF issue.
Every time a design something, (most of my stuff is to to with laser cutting) and i convert it to DXF, The units shrinks x10!!!
so for example, my piece attached below, shows roughly 280mm on its widest part. But when sending it to the guys with the laser cutter they keep coming to me and saying 'are you sure this manifold flange is meant to be 28mm long?
now i know fusion doesn't export the type of unit (apparently) but it does export the units.
so in that theory they should of got a number that was 280 not 28.
can anyone explain why and whats going on, as i keep having to tell them to upscale it along with getting them to check diameters of the holes etc to cross reference my drawing to theirs!
i have loaded it into trueview and this show exactly the same issue, yet when i use the measure tool in fusion it show 280mm, and the parameters in document settings are set to 'mm'
Can anyone share this same experience or tell me how to prevent this?
added pictures below for reffernece
cheers
steve
