Another day of my life wasted on fusion, insert component garbage nonsense.
- Mute
- Permalink
- Report
So I spent a day tweeking an assembly which had been imported into a larger project.
After updating the assembly in the larger project where it is used I noticed after doing quite a bit of work in the lager assembly that things were off with the imported assembly. Going back to the original component assembly it was fine. I tried redoing my changes with align and capture position. No dice it's still wrong in the imported assembly ?Even after update. I don't care what vodoo and happy dance you need to get fusion to work. If the original assembly is correct who thinks it is professional or even acceptable to have a part that is correct in it's original document to CHANGE when imported to another. How can Fusion ever be trusted with this behavior? Even an error warning that positions were altered from the original would help. HERE IS THE KICKER. When I import the component assembly into a NEW design IT IS FINE! How can send fusion files to be CNC'd without triple checking every detail after I had already done that in the original assembly. I fixed it by breaking the Link removing the assembly and reinserting. So somehow the update function isn't right. I won't even get into the fact that I need to export DXF because DWG doesn't work even with Autocad's conversion tool. Yes caps and yes bold, but no curse words considering I lost a day I can't bill for I'd say that is kind.
