Anomaly when extruding a sketch that touches patterned components
tmostad
tmostad
I have a project that consists of linear pattern of components and when I draw then extrude a sketch that touches the tops of the components I see what looks like a bug. See the screencast.
julia.paganucci
Autodesk Support
Autodesk Support
Hi @tmostad ,
Thanks for posting! I do not see any screencast attached. Can you please post a link to the screencast as well as your design that you are referencing?
Julia Paganucci
Technical Support Specialist
| Autodesk Knowledge Network | My Screencasts | Fusion 360 Webinars | Tips and Best Practices
tmostad
My Fusion 360 started to report an outage so I rebooted and maybe 10 seconds later the outage message cleared and the problem went away. So never mind!
tmostad
Spoke too soon. Problem is still there. Hopefully the screencast will work this time.
julia.paganucci
Autodesk Support
Autodesk Support
HI @tmostad ,
That seems strange, can you please share your file here so that I can take a closer look?
Julia Paganucci
tmostad
https://a360.co/2HFpmkj
(Not sure if I am doing this right)
tmostad
OK, I figured out what I was doing wrong. When I was doing the extrude Join was the default so it was joining the sketch to the pattern which was creating a really funky result. When I switched to new component (which is what I want) then I get the result I want.
