Angular dimension on drawing missing one side line
crueby1
crueby1
This just started this morning on one of my drawing files, was working fine yesterday, and works fine if I create a new drawing. If I create an angular dimension using three points, one of the side extension lines for the dimension is missing. I've tried closing/re-opening the drawing, and restarting Fusion, no difference. Does the same thing for any points on the drawing. Here is a picture of it, with a green arrow painted in to show where the missing line is (not). It should extend down to the center mark just below.
And attached is a video of it in action, showing how all angular dimensions on this drawing are missing the second line, and here is a link to the file showing the problem:
https://a360.co/413AMXk
And this is on the current paid version of Fusion, running on Windows 10.
sandip_dumbare
This is not a desirable or expected behavior. Our QA team is looking into this.
Sandip Dumbare
Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
crueby1
Thanks! Hope they can fix it soon!
mohammed.aliTDPXK
Hello @crueby1 ,
I can reproduce the issue and added an internal defect. I am checking with team if this is expected with 3 points, as I am getting this at other three point selection as well.
Also can you please add a quick video on the 3 points you selected in this case, I can anyway reproduce this in another case. just wanted to replicate on your model here.
cc @sandip_dumbare
Mohammed Adam Ali
Sr. SW Eng. Test
Quality Assurance
Autodesk, Inc.
crueby1
My original post already had a video attachment showing it happening with several different points.
