Always Giving Error Macbook M1
erdogan_buyukbayram
erdogan_buyukbayram
I've been using fusion 360 for 6-7 months. I've been using it for the last 2-3 weeks, and it started giving errors constantly. I'm using it on a computer with a macbook m1 chip. It prevents me from drawing because it gives an error, 10 days until the project delivery and I'm about to go crazy.
RajkumarIlanchelian
@erdogan_buyukbayram Please follow the solution from this article:
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/An-...
It is important that you go to the right folder and also empty the trash can.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
erdogan_buyukbayram
I deleted all. At first it didn't give an error, but I started getting errors again.
RajkumarIlanchelian
If you run activity monitor do you see AdSSO-v2 running? If so then the proper file was not deleted from the right location. Double click on the AdSSo-v2 in the activity monitor and it will show the location it is in. Delete the file from that location AND empty the trash can. Please let me know if this helps.
Autodesk Fusion
Join Fusion Insider
