All my projects are gone
batchelder_jimmy
Message 1 of 22
batchelder_jimmy
I have not opened fusion for about a year. I updated the app and now none of my projects are visible in the file browser. I have been using Fusion for over 10 years so I have had a number of account access problems before but was able to get it sorted out quickly. This one I can't seem to figure out. I have checked my app data folder, it appears I have only one account logged in on my device. My email has not changed. The data is also not visible in mobile apps. I'n my editable documents folder, I see some of my documents but they don't open and there is no user/history data showing up when I click the version dropdown. only the last modified date is populated.
Replies (21)
Message 2 of 22
RajkumarIlanchelian
@batchelder_jimmy Can you please go into Fusion- help - support and diagnostics - Fusion service utility - Gather system info and attach the Fusiondiagnostics.zip
After getting that file can you please run the blow article?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Files-stuck-in-Edi...
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 22
batchelder_jimmy
Here are the logs
Following the article did not seem to change anything.
I don't have the login_ActiveDocuments file in the fusion user id folder.
Message 4 of 22
batchelder_jimmy
Message 5 of 22
RajkumarIlanchelian
@batchelder_jimmy Thanks for the logs - when you go to this location /Users/<username>/Library/Application Support/Autodesk/Neutron Platform/Options/<user id> can you snapshot what you see in this folder?
Autodesk Fusion
Join Fusion Insider
Message 6 of 22
batchelder_jimmy
Message 7 of 22
RajkumarIlanchelian
@batchelder_jimmy Thank you. I do see this file in there login_ActiveDocuments
Autodesk Fusion
Join Fusion Insider
Message 8 of 22
batchelder_jimmy
@RajkumarIlanchelian  I deleted that file and restarted fusion. Still nothing.
Message 9 of 22
RajkumarIlanchelian
@batchelder_jimmy Can you please confirm that you followed all the steps in this article?  Especially the one where you need to make one document editable?
Autodesk Fusion
Join Fusion Insider
Message 10 of 22
batchelder_jimmy
I followed the directions. I made the file editable and went back online. nothing. None of my projects are visible. I have 10 years of projects I cannot access. What do we try next?
Message 11 of 22
RajkumarIlanchelian
@batchelder_jimmy @When you say none of them are visible are you saying that the editable documents is now again populated with files that has the spinning wheels?
Autodesk Fusion
Join Fusion Insider
Message 12 of 22
batchelder_jimmy
@RajkumarIlanchelian after fusion updated, I have literally no project files. There are only the default projects. None of my documents show up in the project browser. I cannot access them online either. The files stuck in the editable section were the only hint that my documents existed
Message 13 of 22
RajkumarIlanchelian
@batchelder_jimmy Can you DM me your email used to register for Fusion? I can check in the back end.
Autodesk Fusion
Join Fusion Insider
Message 14 of 22
RajkumarIlanchelian
@batchelder_jimmy This should now be addressed for you. Can you please login and confirm?
Autodesk Fusion
Join Fusion Insider
Message 15 of 22
lauri_barnhart
Hi @batchelder_jimmy,
I wanted to check in and see if you saw @RajkumarIlanchelian's follow up request and you still needed assistance, or if you found a solution to your question already? Please share any available screenshots or screen recordings so the community can assist you further.
All the best,
Lauri | Community Manager
Message 16 of 22
picante
Hi Rajkumar,
I have the same issue.  I had not used Fusion 360 for over a year.  When I recently opened the program and was required to update, I lost access to all my old files. I see two of the old files in a recovery dialogue box, which advises that they are in a different team.  I've never worked with teams and have only used the one email address to access Fusion 360.  What information do you need from me so you allow me access to my old files?
Message 17 of 22
picante
Hi Lauri,
Message 18 of 22
picante
Message 19 of 22
RajkumarIlanchelian
@picante Can you DM me your email used to register for Fusion?
Autodesk Fusion
Join Fusion Insider
Message 20 of 22
picante
done
