AI Drawings
AI Drawings
90210111
Message 1 of 11
AI Drawings
90210111
I've seen that there's a new feature that Fusion360 can make auto drawings,
for some reason I dont get it (I'm a paying customer)
When will it be out ? I want to use it!
Replies (10)
Message 2 of 11
jhackney1972
You did not mention what Version of Fusion you are using.  Go to Help, About and check against the latest shown below.
John Hackney, Retired
Message 3 of 11
TheCADWhisperer
Message 4 of 11
90210111
this is what I get:
Fusion 360 2.0.17954 x86_64
Message 5 of 11
90210111
you're right, my mistake.
here it is - Fusion 360 2.0.17954 x86_64
Message 6 of 11
jhackney1972
Your Fusion version is not up-to-date so you are not seeing this new feature.  Click on Check for Update under the Help (?) icon.
Message 7 of 11
90210111
It is updated
Message 8 of 11
jhackney1972
There is another issue with your updater because the version number you posted does not match the one I posted in an earlier post which is the latest.  Use the service Utility to repair your application
Message 9 of 11
bentwookie
FWIW, I've found that "Check for Update" is sometimes late to tell me that there's actually an update. For example, I was watching for 2.0.18220 the other week. My Mac picked it up, but when I went to my Windows box to fetch it, the dialog said I was up to date on the previous version. It was only after I opened and closed Fusion a couple of times that I saw it come down.
You might restart fusion a couple times and see it shakes 2.0.18441 loose.
Message 10 of 11
90210111
Ill be waiting , working on windows , hope it works the same ...
anyone from Autodesk can help ?
Message 11 of 11
90210111
This solved the update issue - thanks !
