AdskIdentityManager.exe Error: Access violation - code c0000005
UwUMR
Message 1 of 20
UwUMR
Hi everyone,
I had to reboot my Computer and reinstall everything (same exact windows 11 software and same exact hardware).
Unfortunatly, now Fusion360 crashes after I click on the "connexion" button on launcher.
I tried reinstallations in admin, updating OS, updating drivers, uninstal/reinstal C++, uninstal/reinstal AdskIdentityManager and adsso.
Nothing seems to work, maybe i'm doing something wrong.
Heres the crash's details (in french, sorry) :
Date/Heure: 2023-09-08 13:16:13 +02:00
Application: AdskIdentityManager.exe
Erreur: Access violation - code c0000005 (first/second chance not available)
Nom du module bloqué: IdServicesCore.dll
Adresse de l'exception: 0x00007ffae7c60cee
Code d'exception: c0000005
Replies (19)
Message 2 of 20
RajkumarIlanchelian
@UwUMR What other Autodesk products have you installed on this machine? Which version of Autodesk Identity manager did you reinstall? Technically if you have only Fusion 360 you do not need to have Autodesk Identity Manager installed.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 20
UwUMR
I only have Fusion360, but I instaled identity manager after several login crashes according to a support article (wich is, after verification, dedicated to a similar issue but on AutoCAD and AutoCAD Lt)
UwUMR
Message 4 of 20
RajkumarIlanchelian
@UwUMR Can you please do the following?
1. Close Fusion 360
2. Uninstall Autodesk Identity manager
3. Uninstall AdSSO
4. Restart your machine
5. Go to add/remove program - Select Fusion - modify - This will launch Fusion service utility
6. Run the repair Fusion from here
Now start Fusion. Are you sill crashing or facing an issue? If you are
1. Go back to your Fusion service utility and run the "Gather system info"
2. This will generate 2 zip files - please attach the Diagnosticslogs.zip file here
Autodesk Fusion
Join Fusion Insider
Message 5 of 20
UwUMR
I uninstalled Adsso and IdentityManager, restarted my PC, tried to repair Fusion360, but unfortunatly it still crashing.
So, here are the two DiagnosticLogs.
Thanks again for your help
Message 6 of 20
RajkumarIlanchelian
@UwUMR Thank you for the logs. While we look at the logs, are you able to send in the crash reports to Autodesk? IF so can you give me one of the report IDs?
Autodesk Fusion
Join Fusion Insider
Message 7 of 20
RajkumarIlanchelian
@UwUMR And just to double confirm, if you go to add/remove programs, are there any other Autodesk products listed in there?
Autodesk Fusion
Join Fusion Insider
Message 8 of 20
UwUMR
I have nothing except Fusion 360
Message 9 of 20
RajkumarIlanchelian
@UwUMR @And any crash reports that you submitted to Autodesk and one report Id please?
Autodesk Fusion
Join Fusion Insider
Message 10 of 20
UwUMR
I have the support Case No: 20871580 if it can help but it's closed without solution since i'm on free-use/educative license.
I also submitted a crash report but I can't find the Id anywhrere, sorry.
Message 11 of 20
RajkumarIlanchelian
@UwUMR Can you please direct message me your email ID so that I can search for the crash report in our back end using your email ID?
If you launch the product again, assuming that it crashes, you will get an UI asking if you want to submit your report to Autodesk. IF you hit yes then once it is done submitting it will generate a report ID for you.
Autodesk Fusion
Join Fusion Insider
Message 12 of 20
UwUMR
Thank's, I did it and gave you few informations about my last report.
Message 13 of 20
RajkumarIlanchelian
@UwUMR Thank you for sending me your email ID. I was able to get some more information with that. Please do the following. Note some of the steps below may not be necessary but I am suggesting them so that we are not missing out.
1. Close Fusion 360
2. Go to Add/Remove programs - Look for WebView 2
3. Uninstall WebView2
4. Restart machine
5. Reinstall WEbView2 from here - https://developer.microsoft.com/en-us/microsoft-edge/webview2/
Now launch Fusion 360. What are the results?
Autodesk Fusion
Join Fusion Insider
Message 14 of 20
UwUMR
Sorry, but it seems like i'm unable to uninstall WebView2 even with the cmd as admin, or CCLeaner uninstall feature.
Message 15 of 20
RajkumarIlanchelian
@UwUMR With the information you submitted it shows that the crash is coming from WebView2. Are you not having enough permissions to uninstall Webview 2?
Autodesk Fusion
Join Fusion Insider
Message 16 of 20
UwUMR
I'm the admin of this computer so, I don't really understant why I can't
Message 17 of 20
UwUMR
I tried to do :
cd C:\Program Files (x86)\Microsoft\EdgeWebView\Application\1*\Installer
.\setup.exe --uninstall --msedgewebview --system-level --verbose-logging --force-uninstal
In the Powershell and immediatly reinstalled WebView2.
And... It worked !
Thank's a lot Rajkumar !
Message 18 of 20
RajkumarIlanchelian
@UwUMR Glad to know this now works for you.
Autodesk Fusion
Join Fusion Insider
Message 19 of 20
krissyfreaky
Observer
Observer
Solution install WebView2 directly through WebView2 Runtime Installer Microsoft Edge WebView2 | Microsoft Edge Developer.
thank you!!!!
Message 20 of 20
juanmanuel1236
Observer
Observer
Hi, I had days with the issue moving everything in the autodesk folders, my firewall, antvirus and a lot of things suggested here. A few seconds ago I finally make it work, in my case the issue was the Adsk Identity Manager that didn´t launch, here´s my solution:
Win + R and then rype Regedit, navigate to this path HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Image File Execution Options\AdskIdentityManager.exe
Inside, delete the Debugger registry and relaunch fusion. I did the same with AdskAccessCore.exe
