- Mute
- Permalink
- Report
Hi all,
I'm new to fusion so i may be missing something obvious but when i prepare my model for additive manufacturing in fusion the model is placed on the build plate and there looks like an origin symbol in the middle of the build plate, but on my machine the origin is front left corner......so, when inpost process it, the actual model tries to print off the bed, in the gcode view it is also offset this way. Can i specify my 3d printer's origin anywhere in fusion? as i cannot use it this way.
the machine is a raise3d pro2 plus in case that helps.....
thank you
