- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I originally posted this in the Manufacture board, but realize I should have put it here.
I have one model that I've created that Fusion 360 just doesn't seem to like. The modeling went fine, but this particular solid body doesn't want to generate g-code in the Additive Manufacturing workspace.
I can select a 3D printer, print settings, etc. But, when I hit the "Generate" command, F360 just crashes completely out to my desktop. No errors or report windows, just disappears. There's nothing still running in the background, either.
I've tried other models, and those generate g-code. I even made a cube from scratch and that works fine. Other things I've tried without success: different machine, different print settings, Save Copy As on the body to a new file and try there, export to STEP and re-import, export to STL and re-import, reinstalling Fusion 360, rolling back the Windows 10 build 2004 feature update, logging into a different computer that has Fusion 360 (which also crashes to the desktop).
I have no idea what's unique about this model that Fusion just can't handle it. Any other ideas to try? Anything, in particular, I should look for or investigate on the model itself? (e.g. bad faces, running some kind of solid body analysis, etc.)
