Message 1 of 32
- Mute
- Permalink
- Report
https://a360.co/307gsVd if you run a round insert grooving tool on insert center the turned part looks like a ball which was constricted around the equator. the insert center was correctly set in the lathe....... the sim looks good ??
it seems any of my uses of round inserts leads to trouble. also when you select round insert in tool editor ( grooving tool)the is no diameter call out so i assume it is the width.\
