Adding sketch to project built with offset planes and loft feature
mikea1
Message 1 of 10
mikea1
I built a project with offset planes and the loft feature. I want to add to the face of the project but am unable to select sections of the project to use the tangent plane. I am a newborn to the program, and I am learning as I go. I appreciate any help
Replies (9)
Message 2 of 10
g-andresen
Please share the file for reply and explain what you want to achieve at the end.
File > export > save as f3d on local drive  > attach to post
günther
Message 3 of 10
mikea1
This is the file I am working on. I would like to add facial features and other features on the middle section. Any info would be appreciated, thanks,
Mike
Message 4 of 10
TrippyLighting
No file was attached to your post.
Message 5 of 10
mikea1
Message 6 of 10
g-andresen
what do you want to achieve?
günther
Message 7 of 10
mikea1
I would like to add facial features to the top part and to the center part ie; with the offset plane
Message 8 of 10
jhackney1972
You can use an Offset Construction Plane from the Origin plane for this.  Model attached.
John Hackney, Retired
Message 9 of 10
mikea1
s
Message 10 of 10
mikea1
That works for the bottom section but not for the middle and top section for buttons and facial features. I used offset planes and the loft feature to build this instead of the revolve feature. Obviously I am new at this and probably missing something to accomplish this project, (It is my first one). Is there a tutorial or classes that I can get involved in to learn more about the program?
Thank you,
Mike
