Adding bitmap to trace on chromebook
wdaviesV44AQ
wdaviesV44AQ
I've watched a few tutorials on adding a bitmap image to trace, but when I go to Insert>canvas, a window pops up and there are no files to chose from.  I must be missing something? Again this on a Chromebook.  When I try it on my mac, in the lower left of the window that pops up, there is a button to "Insert from my computer."   This is not present on the chromebook.  I'm trying to get this going for my students, who all have Chromebooks.
Thanks!
sanjana.shankar.goli
Autodesk Support
Autodesk Support
Hi @wdaviesV44AQ ,
Thank you for reporting this. Apologies for the inconvenience. I am able to replicate this behavior on my end as well. I will investigate this and let you know. At the moment, *.png and *.jpg files can still be inserted so please try and use these formats for now.
Sanjana Goli
Software QA Engineer
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
HughesTooling
Thanks!
The Chromebook browser version runs on a remote desktop and has no access to you local drives at all so you have to load canvases from your hub. Same for SVGs. See the bottom of this page for more info.
Mark
Mark Hughes
Owner, Hughes Tooling
wdaviesV44AQ
Thanks for the replies. Mark - totally not knowing what I'm doing here but I followed your instructions and I was able to import a .JPG to trace. The goal here is to be able to get this into a .DXF to send to laser engraver. Hopefully I'm on the right track...?
HughesTooling
For DXF it could be a bit tricky! What's in the design? One way is create a component, then create a sketch in the component and project into the sketch what you need. Next use Save Copy As to export the component to your project on your hub, from there download as a DXF.
Mark
Mark Hughes
