Adding Bends to Solid Objects
s.mckenzie.fugro
s.mckenzie.fugro
Hi
I am currently updating a prototype handle for my company where we want to bend it 30 degrees. I thought this would be a simple task but cant seem achieve it after trying different techniques. I tried to create a sketch where I was planning to draw a line/spline from the end of the gray part to the end to the orange part however couldn't get the line to snap to either end then sweep. Extruding didn't work along with combining them. I had also had the idea of producing a sketch in plan view then change the angle of the lines to achieve that but cant seem to get the plane changed so I can do that & I don't want to redefine the plane as that will change the rest of the sketch.
Warmingup1953
Can you share your file?
