A360 Log in/log outconflict
Message 1 of 17
Hi All, recently I changed my email address on my A360 account from fitty67@gmail.com.au to g.fithall@highview.vic.edu.au and ever since I have had no luck signing in or out of fusion 360, I have tried changing it back since but still no joy, I have recently viewed forums of similar issues with other users but the solution has been within autodesk so I was wondering if you guys could get the team onto my issues to get me back online within Fusion360 thanks for your help cheers Glen
Replies (16)
Message 2 of 17
masa.minohara
Hi @Anonymous,
Thank you for posting in the forum! I am sorry to hear about the issue.
Could you try signing in in this page? If you get any errors, please attach a screenshot here.
Could you also attach a screenshot of the error that you receive when logging into Fusion 360?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Message 3 of 17
Hi attached is the error I clicked on the link above also attached is a photo I what happens in fusion360 when I try to go online it just wont go online and I cant sign out I hope you can help, like I said all my problems commenced when I changed my email address cheers GleScreenshot_20180814-164520_Samsung Internet.jpg20180814_164228.jpg20180814_164238.jpg
Message 4 of 17
masa.minohara
Hi @Anonymous,
Thank you for your response! I've logged the issue with the A360 team for further investigation. (ATEAM-16153)
I will follow up as soon as I receive more information from them.
Masanobu Minohara
Message 5 of 17
masa.minohara
Hi @Anonymous,
What is the current email address for your Autodesk account? Is that the gmail?
Are you still planning to change it to the other one later?
Masanobu Minohara
Message 6 of 17
Hi, Yes it is the gmail account at the moment and yes I would like it changed to the other one g.fithall@highview.vic.edu.au if you can do that for me that would be fantastic it is my school email and is easier for the students to find me, Ive tried changing a couple of times myself but both times I have struck this problem, Thanks again Glen
Message 7 of 17
masa.minohara
Thank you! I'll pass this information to the development, and post an update here as soon as I have one.
Masanobu Minohara
Message 8 of 17
felipe.cordoves
Hi @Anonymous as now the email is set as fitty1967@gmail.com we need you to try change it again to g.fithall@highview.vic.edu.au.
You should go to "My account" --> "security settings" and ones there change your email to g.fithall@highview.vic.edu.au and don't change it back.
After that you should let @masa.minohara know that in case we need to make a clean up.
Best Regards
Message 9 of 17
Hi @masa.minohara @felipe.cordoves I have changed email as requested and works when I log in here but I am still having troubles with fusion 360. when I open fusion 360 an error notice comes up (uploaded below) and when I click on ok it loads my home page and then closes the program automatically hope this helps cheers Glenfusion.jpg
Message 10 of 17
felipe.cordoves
Hi @Anonymous
I saw that you set your new email. We already made a clean up of the data involved so you shouldn't have the issue anymore. Could you please confirm that?
Message 11 of 17
Hi, @felipe.cordoves @masa.minohara I am still getting the same notification posted below when opening fusion 360 and once I click ok it pauses for a few seconds and closes the app. automatically the email side of things seems to be working fine but not the app. I have uninstalled it an re loaded it but that has not helped, Please help Glenfusion.jpg
Message 12 of 17
felipe.cordoves
Hi @Anonymous, as i see this issue is happening with the desktop application. And as you said it doesn't seem to be an email issue (we already discard that option after the previous fix we intent)
Could you please confirm if you can access to your hubs and projects on the web application?  I think it should be on an url like this myhub.autodesk360.com
Message 13 of 17
Hi @felipe.cordoves@masa.minohara I've tried to sign into A360 and this is the error I get(posted below) Ive also signed in to fusion 360 page with success so something is going a miss somewhere. Also when I open up fusion 360 on my desktop it still comes up with the error Ive posted earlier and when clicking on the ok button pauses and shuts down automaticallyphoto.jpg
Message 14 of 17
felipe.cordoves
@Anonymous
"I've tried to sign into A360 and this is the error I get(posted below) Ive also signed in to fusion 360 page with success so something is going a miss somewhere..."
Could you please post the urls you are trying to access and the one that worked fine?
Message 15 of 17
Hi @felipe.cordoves ive signed into http://www.autodesk/product.com/products/fusion360/students-teachers-educators that worked fine when I tried to reinstall fusion 360, Ive also signed in here http;//forums.autodesk.com and that works fine but when I sign in at http://wwwa360autodesk.com is when I get the error message that I posted earlierphoto.jpg
Message 16 of 17
masa.minohara
Hi @Anonymous,
Thank you for your patience. I just heard back from @felipe.cordoves that the issue was fixed at the back end.
Could you check if everything is working now?
Masanobu Minohara
Message 17 of 17
Hi @masa.minohara @felipe.cordoves, everything seems to be back up and running thanks again for your help cheers Glen
