- Mute
- Permalink
- Report
Hi, I'd be very grateful for some pointers. I'm learning to use Fusion, and have created a a model with two components, one board with dovetails and the other board with the interlocking pins. See attached file. The model has parameters defined for most of the variable things, such as the number of dovetails, width, angle etc. I do not claim any credit for this, I've worked through an youtube tutorial!
I want to be able to re-use the components in another file, where I intend to design a wooden cabinet. Critically, I need to be able to modify the parameters for each component independently. I thought that the way ahead would be as follows:- copy, then in the target file, right click and "paste new". This appears to work, but brings up reference failure warnings. Looking at the parameter list in the new component, not all of them have come across. Some of them were computed using the dimensions on the sketch, and as far as I can tell, the sketch doesn't come across?
Having them linked, using a single set of master parameters, is not an option for me as I want to have several boards with different values.
Could someone who knows a bit more than me (!) please offer some advice, it would be appreciated.
Many thanks
Nige
