A challenge rendering
I am having a problem all of a sudden rendering an image.  I did a very similar one a few days ago with no issue.  For some reason not the umbrella has no stripes?  It seems fine in the in-canvas render - does anyone have any idea what I am doing wrong?    -  BTW, I get the same result with our without environment/.Same umbrella - No stripesSame umbrella - No stripesIt should render like thisIt should render like this
TheCADWhisperer
(Delete everything except the canopy if you don’t want to share the entire design.
The first thing I would look at is lighting.
Thank you for your help.  Here is the file with the umbrella and legs
Any ideas?  I have tried all I know to figure it out.
TheCADWhisperer
What is the source of this file?
First thing I notice is that it is a mesh surface body (with errors) rather than a solid body.
Second thing I notice is no Split Faces (but then, it isn't a solid body).
Third thing I notice is that Capture Design History is not turned on???
Did you create this geometry or did you get it from someone else?
Did you use t-Splines (Form) tools to create this geometry?
But it does render for me, so I am not sure what the issue is.
Oh wait a minute - I missed this part of your problem description.
Now I see the issue in Cloud Render.
When did those yellow triangles appear?
